shift sequence for the auto tranny
Old Apr 15, 2005 | 05:35 PM
427AC's Avatar
Could someone please expain the shift sequence when the OD is on and normal thottle is applied. Specifically is the TC supposed to lock up when in third gear? I just took the truck to Detroit Tans. They said the PCM is not sending the signal to the TC to lock up in third gear. However according to Aldata it is supposed to lock in third gear under normal throttle conditions when in OD mode.
Old Apr 15, 2005 | 06:19 PM
RATTLINRAM's Avatar
My 99 does not lock the TC in third when normally shifting using OD. The only time I've had it lock in third is when I have OD locked out.
When driving at around 50-55mph with OD locked out,,,, TC locked,,,, and I push the button to engage OD, it will unlock the TC while in third gear and then shift to fourth unlocked and then lock up the TC again.
As far as I know, all the stock 47RE's shift this way.
Old Apr 15, 2005 | 06:20 PM
ratsun's Avatar
I belive with normal( ) throtle positions it should go 1/2/3/4/4lock
Lock in 3 should only happen when the OD is off. Thats the way mine goes anyway
Old Apr 15, 2005 | 07:53 PM
KennyG's Avatar
I get a lockup in third whether or not my o/d is on or off
Old Apr 15, 2005 | 08:30 PM
427AC's Avatar
That is what I thought too, until I read the Aldata report. Thanks guys
bluepp
25
Jan 18, 2006 12:06 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
Dan_K
May 20, 2005 06:45 PM
Dufrain
16
Mar 1, 2005 12:51 PM
Commatoze
Mar 8, 2003 07:27 PM
