replacing a map sensor
Old Sep 11, 2003 | 07:17 AM
mbw's Avatar
mbw
Hey guys - is the map sensor on a 99, easy to replace for a somewhat mechanically inclined female? I hate going to a repair shop for something that I could do....also how do I go about clearing the error code....
Any help would be greatly appreciated.
Molly
Old Sep 11, 2003 | 07:49 AM
Hired Gun's Avatar
Re:replacing a map sensor
I just replaced mine on my 99 Saturday. Took 5 minutes. Look at the back of
the motor. Almost directly under the insulation for the firewall. Driver side. Right
under a small bracket from the firewall. It is there. I forget the size deep well socket, but that and and extension will fit
perfectly. Just slide the wire coupler off, put the wratchet on, and it wont take much to loosen.
Its almost scary how easy it is to do.
As far as a code, well I didnt have any code. So someone else can help you there, but most of the time
when a code comes up, if you turn the ignition forward and back three times,
it will clear.
Old Sep 11, 2003 | 07:51 AM
Hired Gun's Avatar
Oh this part is hard to see from the motor area. Look for the two pin or prong plug, and feel for it.
You will find it I promise.
Old Sep 11, 2003 | 09:30 AM
banshee's Avatar
Does anyone know what size it is? I want to clean mine, but I don't have a deep well that large.
John
Old Sep 11, 2003 | 09:48 AM
mbw's Avatar
mbw
Hired Gun-where did you order your map sensor? Seems like my local parts store is a little pricey ($110)...
Old Sep 11, 2003 | 10:41 AM
Timinva's Avatar
DTR Advertiser
It takes a 11/4" deep well, I paid $47.00 at local Cummins dealer. Part #3348747 it only takes a couple of minutes, but ensure you oil the o ring prior to putting it in. Tim
Old Sep 11, 2003 | 11:18 AM
banshee's Avatar
Thanks, Tim!
Old Sep 11, 2003 | 01:07 PM
Hired Gun's Avatar
Yep thats the part number and the price. Shipped from cummins in a couple days.
Hope this has helped.
Old Sep 12, 2003 | 06:47 AM
mbw's Avatar
mbw
Drove two hours to the Cummins dealer and got the part there. Truck runs great again. Thanks for everyone's help!
Molly
Old Sep 12, 2003 | 04:05 PM
Valkyrie97's Avatar
Muted User
I'm pretty sure it's 32mm on the socket. Do yourself a favor and when one of those fundraiser tool sales comes to your area pick up a set of 1/2 inch drive sets in metric and standard deepwell. Fire departments usually have these guys come around to help them raise money and for the price you will usually have the size you need for almost anything on your truck and you'll help your community. ;D Mike
Old Sep 13, 2003 | 01:16 AM
Haulin_in_Dixie's Avatar
Hmmmm, Valkyrie, Isn't that the one they call a "naked wing"
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
