replaced speed sensor, now....
Old Aug 17, 2005 | 03:04 PM
igotboth's Avatar
Question replaced speed sensor, now....
Abs light and e brake light were staying on all the time, brakes would lock every now and then and the speedo would jump around, replaced the speed sensor on the rear end and now when you turn on the key all the lights flash and you can here a ticking inside for about a minute and a half then symptoms return like before.....need help quick on edit its a 98.5 dually 5 spd
Old Aug 17, 2005 | 07:16 PM
mini14's Avatar
i think u have to set the correct air gap between the sensor and the tone ring.make sure the sensor is close enough to the tone ring to pick up the signal.
Old Aug 17, 2005 | 08:50 PM
J BODY's Avatar
No gapping required. Time for a dealer visit as the DRB is needed to access the ABS module.
Old Aug 17, 2005 | 10:56 PM
fschiola's Avatar
Do you have 4 wheel ABS?
Do the lights stay out until you start driving and then come on at a certain speed?
Old Aug 18, 2005 | 09:43 AM
igotboth's Avatar
No they stay on..anyone else. thanks for the replies
jbprice1
Mar 2, 2013 10:16 AM
homermandy
Mar 13, 2010 09:46 PM
sjester
May 10, 2007 05:03 PM
sjester
Nov 24, 2004 07:28 AM
Bluedeviltorque
Aug 30, 2004 07:12 AM
