Redline MTL in NV4500?
Old Oct 21, 2006 | 10:37 AM
JackRAK's Avatar
I got a good deal on some Redline MTL. However, I have an NV4500 transmission. Will the MTL be OK in the 4500? I read about the greatness of MTL in the 5600, but most of the posts regarding the 4500 discuss using MT-90 or MT-90 mixed with MTL. I don't tow or haul heavy. Any comments?
Old Oct 21, 2006 | 02:32 PM
D-Roc's Avatar
I don't know a hell of alot about the NV4500, but what I DO know is that you should use the recommended lubricant for that trans which is Castrol Syntorq 75W85, I believe. Don't take any chances with your tranny.
Old Oct 21, 2006 | 10:24 PM
Tate's Avatar
I'm running the MTL. It helped shift speed a bit, but nothing crazy. It does leak more now that I put the Redline in.
Old Oct 21, 2006 | 11:10 PM
Ruralmedic's Avatar
It may work just fine. A tad lighter on the viscosity side, but it's a full synthetic GL-4 lube that's designed for manual transmissions. It has the proper coefficient of friction, to allow the synchros to function well, and is friendly to yellow metals.
I believe Redline themselves recommends the 50/50 mix of the MTL/MT90 to acheive that 75W-85 grade for the NV4500.
Old Oct 22, 2006 | 07:35 AM
PourinDiesel's Avatar
As I remember the MT90 from redline is more along what you need for the nv4500.
You can get MTL or MT-90 @ www.synlubes.com
CumminsRedneck
Oct 13, 2014 04:49 AM
SSV1761982
Nov 18, 2004 06:00 PM
Big Jimbo
Aug 27, 2004 02:49 AM
DuaneWKKC
21
Aug 27, 2004 01:42 AM
AKDSLDOG
Oct 30, 2003 08:47 PM
