rebuilt tranny wont go forward!
There are so many possibles it isn't easy.
did you disassemble the VB? Are all the check ***** in and in the right places?
Did the rear clutch get put together correct?
Are you planning on doing a pressure check?
it has a goearand valve body and tc that was in it before i broke my input shaft. i didn't mess with vb. i just pulled the clutches apart and put new steels and clutches in. but i put the one piece input in so on that piston i put new seals in i dont understand what i did.
yea i'm not sure what's going on today i pulled it out of the garage and it worked perfect again didn't have time to mess with it or take it for a test drive but it was holding solid in the drive way as in spun the tires on wet concrete before it didnt even move so i will mess around with it 2mro ill let ya know whats going on !
abc4yew
28
Oct 30, 2024 04:25 PM
xxxqme
Aug 12, 2005 05:12 AM
