Rearend Fluid???
Old May 26, 2008 | 01:28 PM
dspoon's Avatar
Rearend Fluid???
I want to change the rearend fluid today but have no idea what type of fluid to use?? It is not a LSD rearend please help
Old May 26, 2008 | 02:11 PM
smokinram99's Avatar
look at your owner's manual.. I think SAE 90. 80W90 or try synthetic in 75W90 or 75W140 or 85W140. 140 only if you tow or abuse alot..
Old May 27, 2008 | 11:50 AM
nkennedy's Avatar
I have an 01, and just did it with Royal Purple gear lube. I think it was called Gear max.
Old May 28, 2008 | 11:54 AM
Nick02Ram's Avatar
There's usually be a tag somewhere on the pig or bolted onto the rear cover that says what was in it. You can usually tell by the smell, 80w-90 reaks a whole lot worse than synthetic does, if you're around it enough you can tell right away by the smell. As long as you clean it all out good it's not a big deal what you put in it, IMO. Only problem I've come across is if ya mix synthetic with 80w-90, tends to foam up bad.
Old May 28, 2008 | 10:28 PM
brianpgriset's Avatar
Quick question, how can I tell if I have an LSD, other than doing a burnout? I'm changing diff fluids soon and need to know if I should get a friction modifier as well.
Old May 28, 2008 | 10:53 PM
Common's Avatar
Under your hood, there is a small piece of paper with a build sheet of sorts, it'll tell you.
Old May 29, 2008 | 01:32 AM
camelracer's Avatar
Jack up one rear wheel and try to spin it with the tranny in neutral. If it turns easily you have an open dif. A good limited slip will keep it from turning.
Old May 29, 2008 | 09:45 AM
nkennedy's Avatar
The tag in the glovebox will tell you too. I used 75-140.
Old May 29, 2008 | 06:00 PM
Best. Forums. Evar.
Old May 29, 2008 | 07:25 PM
RAFTEN's Avatar
If you get a seal leak after changing to synthetic fluid don't be surpised.
03CTDCO
23
Aug 8, 2007 08:08 PM
abb
Sep 13, 2003 01:13 PM
sshelly
Jun 23, 2003 11:34 PM
big b
Nov 10, 2002 03:50 PM
ronster
Nov 1, 2002 04:14 AM
