Rear Crank Seal
Old Aug 12, 2007 | 12:54 PM
Deezel Nate's Avatar
Rear Crank Seal
Is this the rear crank seal, or is there something else behind the adapter plate?
Old Aug 13, 2007 | 01:26 PM
Ok figured it out that it's the crank seal. Thanks for all the help
Anyone install one of these without the "special" seal driver?
Old Aug 13, 2007 | 07:28 PM
WestTN's Avatar
Never changed one, but the crank MUST be clean and dry. Do not lubricate the seal. Any oil under the teflon seal will cause seal failure in short order.
Old Aug 14, 2007 | 12:31 AM
Tate's Avatar
Seal installation tool should come with the seal. If you take out the adapter plate, there is the seal housing behind it that is 8 or 10 bolts and remove it.
Is that a picture of your truck? Did you clean it before hand? If not, I wouldn't touch that seal.
Old Aug 16, 2007 | 11:41 AM
Yup that's my truck. I wiped it down a bit. The seal is weaping a little bit though it doesn't show in the picture very good. If it were easy to get too, I wouldn't bother, but I don't want to have to pull the trans back out for it in the future.
Old Aug 29, 2007 | 03:20 PM
Got it in there, wasn't too bad, though I should have just pulled the adapter plate and done it that way. I didn't know about it till I had already bought the seal and didn't want to make another trip up to Boise just to get the retainer plate gasket.
Old Aug 29, 2007 | 04:40 PM
Tate's Avatar
The seal I bought actually came with the gasket for the seal housing.
Old Aug 29, 2007 | 07:05 PM
What I got had the crank seal, install sleeve and 2 drivers. There was a thick white one I'm not sure what it was for. Was labeled "rear gear train engines"
Old Aug 30, 2007 | 06:50 AM
Tate's Avatar
I believe the 4 cylinder ISB's as well as the industrial engines use the geartrain at the rear of the engine instead of the front like the automotive ones.
Rimcrew
Aug 19, 2012 01:04 PM
sootnsmoke
Jul 17, 2011 06:31 AM
92smokin blacky
Mar 6, 2011 01:09 AM
92smokin blacky
Feb 28, 2011 02:36 PM
Hammered Scout
Apr 11, 2007 07:10 PM
