question about fuel pressure
Old Dec 29, 2005 | 07:36 AM
bluedodge3500's Avatar
This site is great first of all
I installed a fuel pressure gauge from geno's,at idle its 14psi at cruising its around 10 to 11psi but when I full throttle it it goes to 4 psi then creeps back up I have an edge comp set to 5 on 5 I read most of the threads on this and from what read it shouldnt go below 7 psi but mine does no codes yet so I am just wondering if its alright or should I replace the pump it was replaced with vp about 6000 miles ago I have 80000 on it now thanks
Old Dec 29, 2005 | 07:50 AM
Shovelhead's Avatar
Administrator / Scooter Bum
If you haven't done so yet, you might think about adding an aftermarket
fuel line/fuel fitting setup to increase the flow.
I gained 1 to 1 1/2 PSI of fuel pressure across the board
after installing my Scotty Smart Fuel system.
Old Dec 29, 2005 | 07:55 AM
AltavistaLawn's Avatar
Now that I finally have a FP guage, I can chime in .
At idle I have 14psi..15 cruising at 60. I t doesn't vary much.
I have the Vulcan relo kit with a carter pump from Napa.
Old Dec 29, 2005 | 08:16 AM
P.J's Avatar
P.J
Vulcan here too. Cheaper than scotty, maybe not as "clean" of a set up, but accomplishes the same task.
I also recently saw that someone on Ebay is selling the same kind of kits with the ~an style fittings, it even came with the valve and fittings to hook up a gauge to.
Once you see a "big line" kit, you'll wonder how diesel even flowed thought those sad little banjo fittings.
Old Dec 30, 2005 | 08:45 AM
well I guess my next step is a fuel system thanks
dodgeguy71
17
Jan 19, 2012 12:52 AM
jimbo486
May 5, 2010 06:44 PM
OldDodgeOwner
Feb 13, 2009 05:13 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
