Pusher pump pressure?
Old Nov 2, 2005 | 10:39 AM
MARKY MARK's Avatar
I am planning to put the BD pusher pump kit back by the tank. The pump used in the kit is the Carter P4601HP which puts out a maximum of 18 psi. Will using this pump in addition to my stock lift pump, which is putting out 11-12 psi at idle, 10-11 cruising and 8 wot, be too much pressure? Or should I use a different pump for the pusher pump kit?
Mark
Old Nov 2, 2005 | 02:00 PM
Tiny's Avatar
I put a Holley Blue in line, 14psi, with the stock lift pump. It absolutely buries the 16psi gauge I have now, but I get no hard starts so I am happy.
Old Nov 2, 2005 | 03:50 PM
george7941's Avatar
I had hard starts. Check out https://www.dieseltruckresource.com/...re+arithmetics
Old Nov 2, 2005 | 04:02 PM
MKELLY's Avatar
I use a Holley Red with a Cummins lift pump and my fuel pressure @ idle is 22 psi, no hard starts here. The Holley is rolling on 2 yrs without any issues.
Old Nov 3, 2005 | 08:07 PM
Big Deezul's Avatar
same here 22 at Idle with the BD kit
Old Nov 4, 2005 | 10:51 PM
KennyG's Avatar
Thumbs up
Marky....I am using that exact setup from BD. You WON'T get any hard starts due to over pressure on start ups. This kit comes with an oil pressure switch which easily connects to the extra oil outlet plug next to turbo oil supply. The pusher pump that is included (Carter P4601) is controlled by this pressure switch. Here's what happens... You turn your key and truck starts with your stock pump only operating. Once the oil pressure has risen (momentarily); this activates the oil pressure switch which sends power to your pusher pump. This works very well. My pressure is around 24 @ idle. BD did their homework with this kit! Here's the link:
__________________________________________________
http://www.bd-power.com/ram/product....%20Kits&tt=ram__________________________________________________
KennyG
Old Nov 5, 2005 | 09:58 AM
MARKY MARK's Avatar
Thanks. I'm definitely going with the BD kit.
Mark
Old Nov 6, 2005 | 03:24 PM
yamroamer's Avatar
Hi guys
I`m running a stock 2002 2wd 2500 24v ctd which I have had for 18 months.Would fitting a pusher pump kit prolong the life of my lift pump or is it just a performance mod.
Thanks Van
Old Nov 16, 2005 | 01:14 PM
flippinfred's Avatar
pump question
From what little I know (but have read plenty here) the main purpose is to
help prolong the life of the Injection Pump, not the lift pump. Most don't have
much regard for the stock lift pump anyway. It does seem to be better to
relocate the stocker back near the tank and let it push fuel rather than pull
it through that long hose!
That is my next mod, anyway.
Good Luck!
ps: are getting parts locally a problem for you?
Old Nov 16, 2005 | 01:17 PM
Big Deezul's Avatar
These BD kits work awesome..you will have zero starting problems and they supply everything you need to do the install (minus tools and time) They are not a performance upgrade at all
Old Nov 16, 2005 | 11:33 PM
Sixpack's Avatar
The pump in the BD kit is a 7 psi 100 gph, is it not?
Old Nov 17, 2005 | 09:13 AM
clhumm's Avatar
what would be the difference between the BD set up and using a Vulcan big line kit with a Carter/Holley pump?
Old Nov 17, 2005 | 05:12 PM
yamroamer's Avatar
Good Luck!
The 5.9 cummins engine is very popular in the uk,so getting engine parts won`t be a problem.Any other parts would have to be shipped from the US.
Old Nov 17, 2005 | 07:12 PM
TNutcher's Avatar
The BD setup has an oil press. sensor and once the oil press comes on it lets current reach the pump and turns it on once the motors going not during startup so youll only have the stock lp doin its thing at startup. If u do wire the carter/holley inline w/the stock using a relay to follow how the lp runs (2 sec's b4 startup and less current during starting then full on again) it does fine. Roll On
T
Old Nov 18, 2005 | 01:01 PM
clhumm's Avatar
thanks for mentioning about wiring the holley/carter. but what i was meaning is performance wise, is the big line kit better bc it has larger tubes for better fuel flow or do both kits have the same size tubes. besides the oil sensor switch feature on the bd, what is the difference/advantage of the 2 systems. thanks
hummel
