Pusher pump pressure?
I am planning to put the BD pusher pump kit back by the tank. The pump used in the kit is the Carter P4601HP which puts out a maximum of 18 psi. Will using this pump in addition to my stock lift pump, which is putting out 11-12 psi at idle, 10-11 cruising and 8 wot, be too much pressure? Or should I use a different pump for the pusher pump kit?
Mark |
I put a Holley Blue in line, 14psi, with the stock lift pump. It absolutely buries the 16psi gauge I have now, but I get no hard starts so I am happy.
I had hard starts. Check out https://www.dieseltruckresource.com/...re+arithmetics
I use a Holley Red with a Cummins lift pump and my fuel pressure @ idle is 22 psi, no hard starts here. The Holley is rolling on 2 yrs without any issues.
same here 22 at Idle with the BD kit |
:) Marky....I am using that exact setup from BD. You WON'T get any hard starts due to over pressure on start ups. This kit comes with an oil pressure switch which easily connects to the extra oil outlet plug next to turbo oil supply. The pusher pump that is included (Carter P4601) is controlled by this pressure switch. Here's what happens... You turn your key and truck starts with your stock pump only operating. Once the oil pressure has risen (momentarily); this activates the oil pressure switch which sends power to your pusher pump. This works very well. My pressure is around 24 @ idle. BD did their homework with this kit! [guitar] Here's the link:
__________________________________________________ http://www.bd-power.com/ram/product....%20Kits&tt=ram__________________________________________________ KennyG :cool: |
Thanks. I'm definitely going with the BD kit.
Mark |
Hi guys
I`m running a stock 2002 2wd 2500 24v ctd which I have had for 18 months.Would fitting a pusher pump kit prolong the life of my lift pump or is it just a performance mod. :confused: Thanks Van |
pump question
From what little I know (but have read plenty here) the main purpose is to
help prolong the life of the Injection Pump, not the lift pump. Most don't have much regard for the stock lift pump anyway. It does seem to be better to relocate the stocker back near the tank and let it push fuel rather than pull it through that long hose! That is my next mod, anyway. Good Luck! ps: are getting parts locally a problem for you? |
These BD kits work awesome..you will have zero starting problems and they supply everything you need to do the install (minus tools and time) They are not a performance upgrade at all
The pump in the BD kit is a 7 psi 100 gph, is it not?
what would be the difference between the BD set up and using a Vulcan big line kit with a Carter/Holley pump?
T |
thanks for mentioning about wiring the holley/carter. but what i was meaning is performance wise, is the big line kit better bc it has larger tubes for better fuel flow or do both kits have the same size tubes. besides the oil sensor switch feature on the bd, what is the difference/advantage of the 2 systems. thanks
hummel |
