Pulling bottom end?
Old Sep 1, 2006 | 09:27 PM
krmn59's Avatar
Pulling bottom end?
Hi,
I have a 98 24v that I has a spun bearing.
Is it possible to pull the bottom end apart without removing the engine.
I installed a BD exhaust brake and was testing it out at about 50 mph with no load in truck and my engine spun a bearing , any body heard of this before?
Thanks,
Rich
Old Sep 1, 2006 | 09:45 PM
mgstroker95's Avatar
that suxs bro sorry to hear! Good luck Someone helps this guy !!
Old Sep 2, 2006 | 12:20 AM
Smkndzl's Avatar
if you spun a bearing , the crank will have to come out , so yes the engine must be removed.
Old Sep 6, 2006 | 12:53 AM
Rsquared28's Avatar
I don't think the pan will come off with the engine in the chassis anyway.
Old Sep 6, 2006 | 08:04 AM
nitrousn's Avatar
How do you know it spun a bearing? If in fact it did i am sure the crank and rod will need work or replacement. So if the spun bearing is the case you might as well pull the motor. And no spun bearings are not common.
Old Sep 6, 2006 | 07:01 PM
CTD NUT's Avatar
To my knowledge, there is virtually no way to accurately diagnose a spun bearing unless the bearing, cap and seating areas are adequately inspected which obviously means a complete disassembly.
I have a never heard of a 5.9 CTD spinning a main or rod bearing.....from my experience, I would have to agree with nitrousn and say that it is definitely NOT a normal occurance.
How did you come to the conclusion that a bottom end bearing has spun?....and what does using an exhaust brake have to do with spinning a bearing? I'm not trying to give you a hard time - I'm just very curious.
Old Sep 7, 2006 | 09:41 PM
scottsjeeprolet's Avatar
Ya tell us more. You got my attention now. Did a Cummins shop tell you this?
Old Sep 7, 2006 | 10:13 PM
dodgezilla04's Avatar
i constantly use my exhaust brake, empty or loaded, high speed or slow. an exhaust brake will not cause a spun bearing.
if you are hearing a horrible noise, it may be a valve. the 2nd gen trucks need upgraded,60 lb, exhaust springs so the valves stay shut and not strike the piston. unless you changed the springs, there's your problem. it is very unlikely you spun a bearing, these bottom ends are bulletproof, most sled pullers dont even touch the bottom, and they do WAY more abusive stuff than an e-brake can dish out.
good luck.
Old Sep 7, 2006 | 10:38 PM
BigBlue's Avatar
good luck.
I thought it was only the 12v that needed the upgraded springs?
Old Sep 7, 2006 | 10:42 PM
i could be wrong, ask my wife, it happens all of the time.
Old Sep 7, 2006 | 10:47 PM
"Exhaust Brakes - Dodge Pick Ups
D 2023139 2004.5-2005 Turbo Mount Air kit A Dodge
1027338 2004.5-2006 Remote Mount for 4" Exhaust A Dodge
2023138 2003-2004 Turbo Mount Air kit A Dodge
1027139 2003-2004 Remote Mount for 4" Exhaust A Dodge
2033137 1999-2002 Turbo Mount Vac A Dodge
2033135 1989-1998 Turbo Mount Vac 60# springs A Dodge
1040050 1988-1993 Pipe Adapater Kit A Dodge
1027133 1989-1998 Remote Air 4" 60# springs A Dodge
1027135 1994-2002 Remote Air 4" A Dodge
1030060 Valve Spring kit 60# Cummins 5.9 12-valve A Dodge
1030030 EGR operational kit CA 96-98 A Dodge"
copied from BD's website tonight. shows '98 needing 60# springs. I still could be wrong.
Old Sep 7, 2006 | 10:52 PM
gcookieman's Avatar
The pan can be removed on 4x4 i dont know about a 2 wheel I searously doubt a spun bearing.
By the way why do you use the brake all the time? just curious
Cookie
Old Sep 7, 2006 | 11:01 PM
BigBlue's Avatar
98 was when they had both the 12v and 24v in it. I know for a fact that the 12v's need the upgraded one's and I'm about 99.9% sure the 24v's don't.
Old Sep 8, 2006 | 06:23 AM
CTD NUT's Avatar
I use my EB ALL the time - empty or loaded.....there really isn't much need for service brakes when using the EB empty.
98.5 - 02 24v's do not require heavier exhaust valve springs as the OEM's are adequate.
Old Sep 8, 2006 | 09:35 AM
see, I told you I was wrong. thanks boys
