pto wire?
Old Dec 16, 2005 | 09:16 PM
mooseman's Avatar
pto wire?
Tonight I found a wire tagged pto in the harness under the seal between the hood and the cowl. Whats it for? Is it somehow used to ramp up rpm for the pto?
Thanks Mooseman
Old Dec 16, 2005 | 09:52 PM
Haulin_in_Dixie's Avatar
That wire on a second gen will do you no good unless you are actually using a pto and it is hooked up to function when the pto is in operation. It does not affect control of the engine or idle but changes a couple of perimeters in the computer to work with the pto use.
A careful checking of the service manual will describe the function of this wire.
Old Dec 17, 2005 | 10:18 AM
mooseman's Avatar
Thanks for the info. I was hoping it could be used for a high idle.
Mooseman
Old Dec 17, 2005 | 10:30 AM
mini14's Avatar
there were many discussions years ago about this wire. on dodge trucks it disables certain functions when give a positive 12v charge. do not ground the wire. ive read before, it will not ramp up idle. if we had the 100 pin ecm used on the commercial applications this wire when given intermittent 12v charges will increase the idle incrementally 3 successive times, the fourth time a 12v charge is given it will go back to standard idle.
Rollin Smoke
Oct 24, 2006 10:24 PM
Txwelder
Feb 11, 2006 10:32 AM
matthopp
May 11, 2004 04:38 PM
Haulin_in_Dixie
Oct 16, 2003 11:43 AM
TPilaske
16
Nov 22, 2002 08:15 PM
