PS fluid
Old Oct 27, 2010 | 11:07 AM
Dodge Demon's Avatar
PS fluid
What kind of PS fluid to put in 2001?
Old Oct 27, 2010 | 11:30 AM
Dr.Dizzle's Avatar
The second gen trucks require power steering fluid, unlike the third gens which require ATF+4. Redline, Amsoil, and Royal Purple carry synthetic power steering fluids that may intrest you.
Old Oct 27, 2010 | 03:57 PM
gorms's Avatar
I had problems with the pump groaning and grumbling when cold (under 40) and now it's fine with Lucas ps fluid.
Old Oct 27, 2010 | 07:55 PM
clowndodge01's Avatar
I use AMSOIL
Old Oct 27, 2010 | 11:38 PM
dodge24's Avatar
Been running Royal Purple Max EZ for a while now. No complaints, it works very well!
Old Oct 28, 2010 | 05:13 PM
KATOOM's Avatar
The PS fluid is one of the most neglected fluids. Because of that, its not uncommon to read about steering and braking issues in cold weather. Since the PS pump also powers the brakes too. Changing over to synthetic PS fluid will not only cure any issue (except something major) but it will also make your PS a lot smoother as well. I found some Redline PS fluid and bought a cheap plastic hand pump w/hose that reached down deep in the pump so that I could suck out most if not all of the old fluid. I pumped out about a litter and then refiled with the Redline, drove it a mile or two and then did it again. Some guys claim that a turkey baster works but I couldn't get it to reach far enough.
Old Oct 28, 2010 | 06:08 PM
Danderson's Avatar
What a turkey!
On my '98.5,I used a turkey baster and evacuated the reservoir 6-8 times over a week or so. Each time I replaced the fluid w/Valvoline Synthetic PS fluid. It came out great. I could definitely feel the improvement. Read about it on another forum. It's calculated to exchange 90% of the fluid with no disconnecting or priming. 1 1/2 bottles did the job.
LockedandLoaded
Jan 17, 2008 02:51 PM
Tommy93w350
Jun 26, 2007 04:42 PM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
