Need measurement from a 2wd longbed 5spd
I am getting everything together for the 5 speed swap, but the guy I bought this stuff from gave me too short of a driveshaft. So I am going to take this small shaft to a shop and have them lengthen it to fit. Only problem is I wont have the trans in until fri night/sat morning and they close at five on fridays. So what I need from someone is a measurement of the front part of the two piece driveshaft. From the center of the u joint on the slip yoke to the center of the carrier bearing.
Almost forgot... The truck needs to be 2WD, extended cab, and has to be the NV4500
Please Help! I have to drive this truck back to school sunday night so I really need to have everything before closing time on friday.
Thanks in advance,
Lance
Thanks in advance,
Lance
I'd hate to lead ya in the wrong direction, but my NV4500 was 1/2" shorther than 47RE. This is a 4wd application.
I measured several times to confirm this with my swap before I installed, and it proved true once in. I was able to use the old shaft, still plenty of spline on it. Measure the old vs. new if you can, tape measure doesn't lie much.
Ya I have measured them over and over, the Nv is about 6 inches (guesstimate) shorter than the 47re.
The only reason I need measurements is because the driveshaft shop wants me to have the tranny in the truck, but if someone will give me the length I can just have them make it that long.
Thanks for responding gorms!!!
I dont have much luck getting replies anywhere else
Measure Your Shafts!!! haha
You can get a half dozen different measurements from a half dozen trucks. You are better off waiting until you have everything mounted and get the correct measurements. I keep moving a gear vendors overdrive around from truck to truck and in 4 trucks they all used different shafts even if they are the the same basic body. It'll drive you nuts!
Ok thanks guys, I got the auto pulled early this morning and got the five speed in by about noon. Made the measurements and it matched yalls. The bolts I got from fastenal were 40mm and the flywheel bolts need to be 34mm so I cut them all down. Got the flywheel and clutch mounted tonight. Gonna finish it tomorrow. \
Thanks
-Lance
Thanks
-Lance
dieselfuelonly
Aug 30, 2008 11:08 PM
dcorneli
Mar 12, 2004 08:13 AM
R-O-B
13
Mar 16, 2003 11:59 PM
