Proper IP Pressure Tranny number
Old Jun 20, 2005 | 09:36 AM
phal's Avatar
I tried the search on this subject and had no success, partially I think because the search function would not let me use IP instead of Injection Pump in the search.
I have 2 questions:
2001 24 valve - What is the proper injection pump pressure?
Can any one tell me which automatic this truck has?
Thanks...gary
Old Jun 20, 2005 | 11:53 AM
CTD NUT's Avatar
Your truck has a 47RE auto tranny. Do you need to know what pressure the IP pumps to the injectors? That, I'm not sure of, but think it is well over 10,000 psi.....maybe someone else can chime in on that. Why do you need to know that? Do you mean what LP fuel pressure should the IP receive? If so, 5 psi is the minimum WOT pressure. You should have 12 - 15 psi at idle and about 10 - 13 psi at cruise.
Old Jun 20, 2005 | 06:26 PM
phal's Avatar
Thanks Nut
that was what I needed. Flying out to buy the truck on wednesday...gary
Old Jun 21, 2005 | 06:00 AM
CTD NUT's Avatar
Cool! Good luck.....are you taking a fuel pressure gauge with you? What year CTD? 00 and later you can check the codes on the odometer display by cycling the key 3 times. I would highly recommend a code check before you buy.
jurish
May 5, 2010 01:39 PM
by2005
Sep 1, 2006 10:12 AM
Bushy
Jul 16, 2005 01:50 PM
Hummin Cummins
Feb 1, 2003 07:03 PM
Pineapple Kid
Nov 30, 2002 01:56 PM
