Problem Wuth Turbo
Problem Wuth Turbo
im having a problem with the turbo when im crusing it trys to cut off i push in clutch rev the engine turbo works again could this be a leak in the hose causing it to suck air is turbo dirty its a 99 dodge 3500 24valve cummins any ideals?
The amount of boost you see depends on the load on the engine. The turbo is strictly mechanical. Exhaust flow determines the drive pressure which, in turn, controls boost pressure. If the fuel system is okay, then you are probably just seeing the effects of driving slightly down hill.
59smith06
Sep 7, 2009 08:16 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
