Power steering box problems..
Old Dec 1, 2003 | 01:19 PM
Smokedawg's Avatar
Anyone here have problems with there power steering box top loosing. About every 2 weeks I was having power steering problems and kept adding more fluid until I found out the problem. The 4 bolts on top of the power steering box were loose. I tightened them down and all was good for about a month and then they worked loose again. I put a new gasket on and lock-tighted the bolts and everything has been cool for about 2 weeks.
Is this a problem on all these or am I just lucky
2001 CTD 3500
Old Dec 1, 2003 | 04:49 PM
Kimrey's Avatar
Re:Power steering box problems..
I haven't heard of any, but I wil check mine! Good luck!
Kimrey
Old Dec 2, 2003 | 08:03 AM
BarryG's Avatar
Smokedawg:
I had that problem a couple times myself and have heard of others as well. I just tightened them up and then about 6 months later it did it again. A couple of those bolts are hard to get at. Second time around I torqued em down a bit more and haven't had a problem since and its been about 2 years now. I think what you did should solve your problem.
Old Dec 2, 2003 | 09:24 AM
Diesel Dave's Avatar
From what I have read on this site and some others, this is a fairly common problem. I had to tighten the bolts on my truck also.
Old Dec 2, 2003 | 11:44 AM
Palmetto_kid's Avatar
What exactly is the power steering box? every now and then when i start up and take off the steering is hard. i wanna check mine now that we are talking about it, so where is it located?
Old Dec 2, 2003 | 01:38 PM
When I replied earlier, I assumed "power steering box" just meant the steering box. If that is what you want to check, it is located in the drivers side front of your engine compartment, to the side of the engine.
Old Dec 2, 2003 | 04:05 PM
Smokedawg's Avatar
Any other known problems to check up on???
Old Dec 3, 2003 | 09:24 AM
I would check to make sure that your intercooler hoses are not rubbing on anything and that the clamps are tightened on all of your hoses. Some have had problems with the hoses rubbing and cutting holes in the hoses near the intercooler. I would also get gauges if the truck doesn't have them. Lift pumps are a problem on these trucks, so you definitely want a fuel pressure gauge. Many guys, myself included, also have an egt gauge and boost gauge.
Dean Snow
Nov 14, 2007 04:36 PM
jkap
Oct 23, 2006 04:07 PM
04ctd
Oct 5, 2006 08:27 PM
LanceK
13
Jul 14, 2006 08:08 PM
unioncreek
Jun 29, 2005 02:00 PM
