Power intermittent
Old Mar 22, 2011 | 07:20 AM
Sharp Dog's Avatar
Power intermittent
While driving and I let up on the foot pedal and the rev's go below 1500 there is a drop off of power. Then when I press down on the pedal there is very little power, hardly enough to accelerate. I push in the clutch and let the engine accelerate above 1600 rev's and it will pick up the power again. This is intermittent and does not happen every time. While I am accelerate the engine with the clutch in there is white smoke coming out of the exhaust until the power comes back. This is happening more frequently each day.
Old Mar 22, 2011 | 07:34 AM
nickg's Avatar
use the search function for "dead pedal"
you will need to pull codes and check your fuel pressure. sounds very much like a failed VP44. pulling codes will help put you in the right direction to start
also read this thread to get up to speed on a VP diagnosis
http://www.bluechipdiesel.com/vp44diagnostichelp.html
Old Mar 22, 2011 | 08:31 AM
Sharp Dog's Avatar
Fuel pressure is good from my FASS pump. If the VP44 is causing this I think it is due the it receiving an erronious signal from some electrical input.
Old Mar 22, 2011 | 11:39 AM
Grain's Avatar
Got a similar issue, but mine is more noticable when in 4th or 5th, although it too is intermittent. Seems like it's getting enough fuel in the first three gears, but not enough in the higher ones. Checked out the APPS, hoping it was that, but no. I too have a FASS delivering good pressure, however I only put the gauge in 10 days ago, so who knows if there was a pressure drop earlier. VP44 is starting to make wierd noises, very quiet to very loud, and burning fuel like crazy. Ordered a VP44 last week, should be here tomorrow. I hope you don't need one, but sounds like you do.
Old Mar 22, 2011 | 05:25 PM
nickg's Avatar
have you pulled codes?
and have you read thru the link provided?
Old Mar 22, 2011 | 05:40 PM
Sharp Dog's Avatar
Yes on the codes and 216 is there. But when you read Blue Chip the 216 code should not have an effect on performance.
Old Mar 23, 2011 | 12:48 AM
nickg's Avatar
you can call him to comfirm it (think its a typo error) but a 0216 is a wore out pump, and it will cause dead pedal, and drivability issues, as the pump is wore out mechanically.
Chip states in the "dead pedal" section if your APPs checks out and you have dead pedal issues you will need a VP.
usually dead give aways to a failing VP are
0216
dead pedal/ power loss
white smoke (unburnt diesel, due to improper timing)
Old Mar 23, 2011 | 07:08 AM
Sharp Dog's Avatar
Thanks for the help
Old Mar 23, 2011 | 11:41 AM
Lil Dog's Avatar
0216 is the pumps inability to maintain correct timing. The white smoke and lost power is an indication of incorrect timing and is not going to get better.
Old Mar 28, 2011 | 01:15 PM
Sharp Dog's Avatar
Thanks for the help
Changed VP44
works fine.
smokester
May 27, 2011 05:31 PM
jaredsund
Nov 1, 2006 02:44 AM
tucherth
Nov 14, 2004 12:58 PM
Ram4Play
Jun 17, 2004 05:36 PM
gregway
Aug 11, 2003 06:19 PM
