Poll : Fuel additives & failures
Old Jun 15, 2006 | 03:55 PM
y2kram's Avatar
Of all the folks that have lost fuel pumps or injector pumps:
1. How many were using fuel additives (on a regular/semi regular basis "prior" to the failure)?
2. How many have never used a drop of additives?
Of the folks that have never lost a pump:
3. How many are using fuel additives (on a regular/semi regular basis)?
4. How many have never used a drop of additives?
Old Jun 15, 2006 | 06:17 PM
jeff-kc9ftp's Avatar
4 lift pumps, 0(so far) injection pumps
Used some type of additive in nearly every tank since new. Power service about 98% of the time.
jeff
Old Jun 15, 2006 | 07:20 PM
Hillcountry's Avatar
3 lift pumps
0 VP44's
Use additive every tank since 1st LP died
104000 Miles so far on IP
Old Jun 15, 2006 | 08:04 PM
JARHEAD's Avatar
2001-1 lift pump, 0 vp44, no additive 182k
1999-0 vp44, put additive in it for first couple of years
Old Jun 15, 2006 | 09:37 PM
POWHATAN RAM's Avatar
2001 1-Lift Pump 0-vp44's
102,000 Stanadyne every tank.
Old Jun 15, 2006 | 11:48 PM
rebal's Avatar
2001 SO 98,000 3 lp 0 VPs no additive ever fass.
2001 HO 105,000 1 LP 0 VPs no additives ever both truck are BOMBED
Old Jun 16, 2006 | 12:06 AM
kipo's Avatar
1- injection
2-lift
changed vp trying to find miss but sounded same after installing one of chips from blue chip. use lucas about 85% of the time. lost the first lift and vp before guages were installed. after install on the way to MO fuel pressure was down to 0. got to MO changed lift pump but never had any problems with vp. ???
Old Jun 16, 2006 | 01:50 AM
H2SRDMB's Avatar
one vp-44 @ 40K
now 1 l.p.( maybe 2 if you count the cause for the 1st vp-44)
using power service for the last 30k miles 104,000 miles on the truck.
had used additive occationally before. but not `till after the new injector pump.
now i use it every tank!!
Old Jun 16, 2006 | 09:31 AM
y2kram's Avatar
No failures
No failures - ever - 150,000 mi
Have never put a drop of additives in the fuel (but I also only use major branded fuels - Chevron, Texaco, Shell)
Old Jun 16, 2006 | 12:25 PM
blackdiesel's Avatar
Registered
1 lp, 2 holley blues, and 2 injection pumps
Old Jun 16, 2006 | 12:53 PM
y2kram's Avatar
w or w/o additives?
with or without additives?
Old Jun 16, 2006 | 02:02 PM
TORQUE's Avatar
1 lift pump changed under warranty at about 100,000kms, had VanAaken towing module on also since day one. Put FASS on at 150,000kms. I have about 230,000kms now, still with original VP-44. I have used Powerservice with Lubricity additive since I bought truck new in May 2000. Also add 4-6 ozs low ash 2 stroke oil every tank. I never run below 1/2 tankfull if I can help it.
Old Jun 17, 2006 | 12:34 AM
Clunk's Avatar
2001 0VP 1LP fuel treatment every fueling, 89K
Old Jun 17, 2006 | 07:43 AM
Pirate's Avatar
changed to FASS after lp issues, may still need IP. Problems started with in 2,000 miles of first using addative. Bought truck with 120,00 miles so unsure of previous additive history. Rarely use additives now but was using for every other tank.
Old Jun 17, 2006 | 03:29 PM
Tom's Avatar
Tom
Lucas since new = 1 LP at 9,950 miles and no VP44 failure to date. The LP worked but did not maintain proper pressures. Apparently caught it just before it went completely out. I'm glad I had a pressure guage.
Not too much driving on this truck though. Truck only has 20,135 on it.
