Pinion/vibrating ?
Old Aug 11, 2007 | 09:49 AM
bluesfan01's Avatar
Pinion/vibrating ?
Has Anyone Ever Bent A Pinion. I Put My Rearend Back Together And Its Vibrating At 45+ Mph.
Old Aug 11, 2007 | 07:31 PM
nickg's Avatar
I'm not sure if the dodge has a master spline to keep the yokes"in phase" or not, Did you seperate the yoke from the drive shaft? I doubt a bent pinion will cause a vibration, but if the bearing preload is off(meaning you can move the yoke/pinion around) then that will cause vibration. a bad hanger bearing will cause a vibration under load and lessen as the truck comes up to speed.
Texaschevelle
Oct 7, 2007 10:08 AM
BigBlue
13
Dec 12, 2005 10:47 PM
jschintgen
Sep 14, 2005 12:00 PM
Hoss
Aug 11, 2005 04:51 PM
