pic of airtex pump?
Old Jan 30, 2008 | 08:16 PM
rockwithjason's Avatar
pic of airtex pump?
can someone post a pic of the airtex pump? i want to make sure i get the right one. thanks
Old Jan 31, 2008 | 12:12 AM
Ram4Sam's Avatar
Just like this....
Old Jan 31, 2008 | 12:36 PM
thanks for that
Old Feb 6, 2008 | 09:06 PM
Redog76's Avatar
that pump makes all the difference. f^%$ a fass pump unless you are gonna go crazy on the motor. the lowest pressure i ever got was 10 psi. git er done
Old Feb 6, 2008 | 11:45 PM
greenwing's Avatar
does airtex mount down on frame as a pusher?
Old Feb 7, 2008 | 01:52 AM
Fishin2Deep4U's Avatar
It can be mounted in either position. The most common application is as a replacement pump in the stock location.
Dave
Old Feb 7, 2008 | 07:39 PM
shawn880's Avatar
save your money for something stronger. ive had it for a couple of months with stock lines in stock position it shows 11-12 psi @ idle and 5 while crusing and can go down to 0 when to the floor. not gonna get it. airdog coming soon. i think maybe with the relocation kit and some bigger lines it may be better, but after all of that im getting the airdog and do it right. like most people say on here, airtex is just a temp fix for a known 24v problem.
Old Feb 7, 2008 | 09:30 PM
sgrol's Avatar
Go with FASS and be done with it.
Old Feb 8, 2008 | 12:11 PM
CORed's Avatar
Or a Walbro... I'm quite pleased with mine... rock steady pressures. Maybe drops 1psi at WOT. I have 3/8" lines and stock filter. It's mounted on the frame. And it's cheaper and quieter than the FASS! Never even a hickup in over a year.
CORed
Old Feb 8, 2008 | 08:47 PM
RAFTEN's Avatar
CORed, if I wanted to get a Walbro like yours what would I ask for?
Old Feb 8, 2008 | 10:23 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Hrm I must be a lucky guy. I got the new version OEM lift pump not sure on the maker but I show 13-14psi idling and nothing below 6psi on it hard around 2500 rpm with a chip on my pickup going on two years now
Old Feb 8, 2008 | 11:10 PM
piperca's Avatar
GS-392
Old Feb 9, 2008 | 10:43 AM
CORed's Avatar
Originally Posted by piperca
GS-392
Yes, that is correct. GDP can set you up. It's the 392 with the install kit.
http://www.glacierdieselpower.com/pr...?pf_id=GSL-392
He also has an entire kit w/ fittings and lines if you want to do it as a system. I plumbed my own since I have a local shop where I can get all the AN fittings and diesel fuel hose I want.
CORed
supr
34
Nov 2, 2010 04:45 PM
Mr. Roper
14
Apr 18, 2008 02:11 PM
rockwithjason
Jan 14, 2008 10:16 AM
CalRoberts
24
Jan 4, 2008 02:50 AM
