PCM ?'s
Old Jul 2, 2005 | 11:11 PM
1BadRam's Avatar
PCM ?'s
Does anyone know which wire running to the PCM supplies the power to it? Please let me know if you do.
Old Jul 3, 2005 | 12:51 PM
neveragain's Avatar
PCM power
I am working from the maintenance manual for the 99. Probably not correct from the publisher.
Says start- run A21 feeds Junction Block
Fuse 11 10A Pins #18 and 17 and Fuse 9 10A Pin # 14 and 13
Comes out 20 LG/BK
Splits @ S171 Feeds ECM 18 LG/BK and PCM 18 LG/BK
PCM pin 2 C1 Fused ignition switch output (st-run)
Hope this helps if not shall try to provide you with more info.
Old Jul 3, 2005 | 11:55 PM
1BadRam's Avatar
Thanks man for the help. I should be able to decipher it.
Big Perm
Dec 18, 2007 08:44 PM
barracuda
Oct 7, 2003 06:07 PM
Lary Ellis (Top)
Jul 10, 2003 12:23 AM
boomer
Apr 24, 2003 02:26 PM
