Overhead on ISB
Old Nov 11, 2007 | 08:17 PM
Suneview_Farm's Avatar
Overhead on ISB
Can you adjust the valves on an ISB? I was just wondering if this needs to be done...truck has 188K...and if it needs to be done what are the intake and exhaust specs and how you adjust the bridges? Thnaks
Cody
Old Nov 11, 2007 | 09:02 PM
scout98's Avatar
Cummins recomends adjustment at 150K There is a good tech article on this subject in the 2nd gen tech articles.
intake .010 exhaust .020 there is some + or - on those specs just do not remember off the top of my head
Old Nov 11, 2007 | 10:42 PM
Tate's Avatar
Allowable lash on the intake is .007" - .015", exhaust is .015" - .030". Like was said, nominal is .010 and .020.
Old Nov 12, 2007 | 05:57 PM
Ok thanks...what about the bridges? Do you adjust those like you would on the 855 Big Cam Series? Or the N-14/M-11 series?
Old Nov 12, 2007 | 11:25 PM
JSPulliam21's Avatar
No clue on how you adjust the bridges on those engines, but the lash on the ISB is checked between the rocker arm and the bridge. No other check or adjustment needed. The tech article really lays it out well with pics. Easy as pie to do as well.
Old Nov 12, 2007 | 11:45 PM
HOHN's Avatar
I wonder if setting the lash on the tight side would drop EGTs by increasing cam duration a little bit.
Justin
Old Nov 13, 2007 | 01:27 AM
Tate's Avatar
Justin
Need to be careful, too tight and you'll start burning valves.
There are no adjustments on the bridges, they just float in there.
Old Nov 13, 2007 | 07:22 PM
Number47's Avatar
yea valves adjust the same as the n14 or m11. put feeler guage between bridge and rocker and adjust the setscrew and lock it done to spec with the lock nut.
H8GAS
18
Aug 3, 2007 06:31 PM
dieselfuelonly
Jan 26, 2007 11:11 PM
possum
May 24, 2005 11:30 AM
Nicholas
Mar 29, 2003 11:22 PM
