Which one is it???
Old Oct 4, 2013 | 03:16 PM
J180mechanical's Avatar
Hard to start after is gets warm...
Got my truck 6 months ago and it was having a little trouble starting after it warmed up so I put in two new battery's and it was a lot better tell a couple days ago it would not start after driving it for awhile. After setting for a while it will start right up?
This is the codes I'm getting:
P-1689
P-1693
And mapp sensor volts to high.
2000 dodge ram 2500
24valve turbo diesel.
Old Oct 4, 2013 | 05:18 PM
patdaly's Avatar
1689 is a communication fail between the VP and the ECU, so when 1689 is active, the truck won't start.
Since yous wont start when hot, I would suspect either an internal issue at the VP44 or a connector issue.
Some more reading for you.
http://forum.mopar1973man.com/thread...cure-for-p1689
http://www.bluechipdiesel.com/vp44_diagnostics.html
Bradleysram
19
May 12, 2009 08:36 AM
usmc2311
Nov 6, 2008 04:18 PM
cameroneod
15
Aug 5, 2007 02:11 PM
12valveford
Off Road / 4x4
Apr 10, 2006 02:57 PM
Wade
Oct 15, 2002 05:29 PM
