Oil pump replacement?
Could be oil pump but it could also be the spring/plunger assembly in the oil filter mount assembly needs replaced.
The spring and plunger can be done by simply removing the 18mm bolt that sits next to the oil filter and putting a new set in.
I would check the pressure witrh an external gauge before doing anything else. It could be the pressure sensor or the oil pump. If you guess wrong, you will then have to replace the other device.
mstep3
23
Jul 27, 2010 02:22 PM
GlennRMK
May 24, 2007 10:46 PM
Bobcat698
Apr 17, 2006 01:48 PM
