Oil Pressure Sensor going bad?
Old Feb 28, 2005 | 09:41 AM
wrk24wheel's Avatar
About a year ago, I had my truck towed to the dealership due to no oi pressure. It turned out to just be the oil pressure sensor. It was replaced and all was well. However, the past two days while driving the check engine light will come on and the oil pressure will hit 0. This will last for up to 20 seconds and then the check engine light will go off and the pressure will return.
We have mechanical oil pumps right? What are the chance that one will go out. I have not really heard of anyone complaining about one dying. But than again, in one year , what are the chances of another sensor dying?
Old Feb 28, 2005 | 10:07 AM
latitud_rt's Avatar
The CEL is most likely coming on because of the senor reporting data that is out of range. I would bet you either have a bad connection or a bad sensor. Check the connection for corrosion. If the connection looks good, just replace the sensor.
Old Feb 28, 2005 | 10:23 AM
wrk24wheel's Avatar
I just hooked up my scanner and I get a MIL code casued by P5023. Anyone know what this is?
Old Feb 28, 2005 | 10:47 AM
crobtex's Avatar
When my op sensor went out, the needle didn't move at all. No codes or lights..........
Old Feb 28, 2005 | 12:00 PM
high country's Avatar
If your code was P0523 not P5023 then P0523 is oil pressure sensor high
Old Feb 28, 2005 | 02:21 PM
PistolWhipt's Avatar
Replace it with a manual guage... I hate sensors.
PISTOL
Redlinear
Feb 14, 2013 01:10 PM
RoadDawg
21
Sep 25, 2008 04:13 PM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
E Janssen
Jul 28, 2004 07:40 PM
