oil/fuel filter change problem
Old Apr 21, 2007 | 07:52 PM
solostyle1's Avatar
truck was running perfect until i did a fuel and oil filter change and now it seems to b starving of fuel maybe. Im only building about 35-38psi of boost whe i was at 45psi. the truck pulsates when i get on it in 4th and 5th gear. any solutions?
Old Apr 21, 2007 | 07:57 PM
wcbcruzer's Avatar
Maybe you got air in the lines. I think you might have to pull an injector line to get the air bubble out if that's what happened.
Old Apr 22, 2007 | 05:17 PM
solostyle1's Avatar
ive been driving it for a week plus now...you think air would still b in the line?
Old Apr 22, 2007 | 05:21 PM
Geico266's Avatar
No. It should all be purged by now.
Old Apr 22, 2007 | 05:23 PM
Hillcountry's Avatar
Is it possible that the gasket on the FF is not right and it is sucking air?
Old Apr 22, 2007 | 05:25 PM
phox_mulder's Avatar
What year truck?
Where is your fuel pressure guage mounted?
I'm going to guess you have a dying lift pump.
When you changed the filter you broke prime, and now the injection pump is having a hard time pulling it's own fuel all the way from the tank.
Assuming this is a 24 valve 2nd gen truck we are speaking of.
phox
Old Apr 22, 2007 | 05:31 PM
belgianmagic's Avatar
IF THIS WERE THE CASE SHE WOULD loose her prime while parked...
I too am thinking air in the lines...BUT it should have perged by now...however if not you may have damaged the cylinders from running them dry...usually
"AT AN IDLE" you make sure all cyls have fuel b4 you go down the road
TRY to crack the connections @ the injecters@ an IDLE
if no fuel PURGE IT
if there is fuel ...
and it is still running poorly with fuel maybe a bad injecter
or you did damage it running DRY Cyls
GOOD LUCK, Flip
Old Apr 22, 2007 | 05:40 PM
wcbcruzer's Avatar
Are you talking about some cylinders in the injection pump?
Old Apr 22, 2007 | 07:41 PM
I was thinking along the lines where if you have a bad lift pump and the seal at the FF was not good, the VP would draw a vacuum. The only reason I even thought that was because of the recent FF change...I sort of assumed tat the LP was dead.
Old Apr 23, 2007 | 12:46 AM
NO I was talking about PISTONS...running dry cylinders gives the pistons NO lube above the pistons
jmccart
13
May 27, 2009 09:45 PM
vegashd
Jul 15, 2007 12:24 PM
Lunyfringe
Jan 10, 2005 05:40 PM
doitl8r
Jun 4, 2004 11:14 AM
XTOAK
17
Aug 23, 2003 09:07 AM
