oil consumption
Old Oct 18, 2004 | 09:57 PM
tenbrooks's Avatar
Question oil consumption
just checked oil level after 5000 miles ,it shows 1 qt low .just wondering is this normal?
Old Oct 18, 2004 | 10:12 PM
Haulin_in_Dixie's Avatar
It's a '99 I would not worry about it. It will use a little, just so it does not go below the low line. You should not have to add oil between changes. Mine is very sensitive to how it is sitting. Checking it at the same location each time gives you a better idea. It varies at different truck stops. It is sensitive to level both side to side and fore and aft.
Old Oct 18, 2004 | 10:32 PM
tenbrooks's Avatar
thanx HID, this truck only has 94000 miles on it (just breaking in)just curious of what was normal use for a cummins. Had been told years ago that mercedes engineers stated that an internal combustion engine should use 1 qt per 4000 miles. It showed that the oiler rings were doing their best job. I dont know if that is their standard now with the tighter clearances.
6cylinders
Jun 13, 2013 03:27 PM
boatpuller
17
Oct 14, 2003 02:51 PM
woolhauler
Aug 14, 2003 09:08 AM
woolhauler
Aug 2, 2003 08:43 PM
ICEBOX
Feb 9, 2003 06:08 AM
