o/d drive light
Old Jan 27, 2010 | 10:49 AM
olddodgetrucks's Avatar
o/d drive light
1999 o/d light goes on after sitting overnight,o/d is off,push button to engauge o/d and works fine for rest of day,trans shifts ok ,nothing else wrong,what to check???
Old Jan 27, 2010 | 12:23 PM
RowJ's Avatar
Pull the button and cover straight out of the shift lever and check wiring. It's just snapped in there and attached by a wiring harness plug with 4-5" of slack. But be careful of scratches. I used a plastic spatula made for spackle.
I use my button a lot. Over 185,000 miles, got a bit harder to engage. Had to be sure and push button all the way in, or no go.
Replacement button is probably the best priced part on our trucks and made everything like new again.
Only have to breath on the switch now, to lock out OD.
RJ
Old Jan 28, 2010 | 10:40 AM
swtich works fine ,just goes out of o/d when standing overnight,start the truck push the button and everything works fine
Old Jan 28, 2010 | 11:20 AM
RowJ's Avatar
Understood that. But in case it's starting to die, just threw in extra info... for future reference.
I'd live with it also.... if it's working ok after startup.
Been around here a long time and that's a firsts for that particular scenario.
Is the OD actually locked out, or is it just that the light comes on at startup? Suspect the second.
Could just be the dash warrning light display isn't going out when you turn the key on?
RJ
Old Jan 29, 2010 | 11:12 AM
trans is locked out of o/drive till button is pushed
Old Feb 3, 2010 | 10:25 AM
anybody,ideas////
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
skymiles
Dec 21, 2006 10:05 PM
Hummin Cummins
Feb 11, 2003 12:14 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
