Which NV5600
Old Jan 21, 2008 | 05:03 PM
Krob's Avatar
Which NV5600
I am curious how i would tell which nv5600 i have. I am looking at new clutches and i see that there are two different clutch sizes how do i find out if i have the 12.?? or the 13.??. Thanks
Old Jan 21, 2008 | 05:37 PM
CJ's Avatar
CJ
I could be wrong but I think the 12" was in the 99-00 ETC and the 13" was in
the 01-02 ETH or basically just the HO model.
CJ
Old Jan 21, 2008 | 07:40 PM
Krob's Avatar
thats whats funny my valve cover doesnt say its a HO model. Were else could i look to find that out i guess i could vin number it at a dealer.
Old Jan 21, 2008 | 07:44 PM
dodge00's Avatar
arn't all 6 speeds Ho
Old Jan 21, 2008 | 07:54 PM
can17's Avatar
I'm pretty sure you have a H.O.
Look for an engine tag under the APPS. It will say either 235 or 245 HP.
Also, in your VIN #, the 8th digit will be "6" if it's a S.O. and "7" if it's a H.O.
Old Jan 21, 2008 | 08:09 PM
Tate's Avatar
6 speeds were an option in 99 an 2k, which was behind the 235hp ETC (SO) engine.
Old Jan 21, 2008 | 08:14 PM
CJ's Avatar
CJ
01 and 02 6spd's are all HO's
CJ
Old Jan 21, 2008 | 11:24 PM
gmctd's Avatar
DEA is 1.250" with 12.250" clutch, starter bolts directly to engine adaptor
DEE is 1.375" with 13" clutch, starter bolts thru a spacer to the engine adaptor
Old Jan 22, 2008 | 02:00 AM
Krob's Avatar
vin number 8 is a 7 so its an HO. I dont know why i started woundering except valve cover doesnt say HO and i read some were about some 6 speeds having smaller clutchs and couldnt remeber the year break. Thanks Rob
Old Jan 22, 2008 | 06:51 PM
Tate's Avatar
Do you have pics of a valve cover that does say HO on it on the 2nd gens?
Old Jan 22, 2008 | 06:57 PM
can17's Avatar
I'd like to know this too.
As far as I know, none of them say HO on the valve cover.
Old Jan 23, 2008 | 12:39 AM
HOHN's Avatar
They don't say HO on the v.c.
A better method is the starter attachment mentioned earlier.
The '99 5600s are rare, and the 00s rarer still.
Suffice, if it's a 6-speed and earlier than 01 model year, you have the smaller clutch.
jh
Old Jan 23, 2008 | 09:34 AM
gmctd's Avatar
With pre-owned trucks, WYSIWYG rules - the starter attachment is the best method, but is still not really definite, as the PO may have gone with SBC or TST redrilled flywheel\13" clutch for the larger input shaft, which would not need the spacer - even the DEA and DEE designations are not totaly sure, as the DEA 1.250" transmission may have been repaired with the 1.375" shaft - that is a direct swapout, with the larger retainer\collar.
However, if there is a spacer between the starter and the adaptor, it is most likely the 13" clutch with the large-shaft DEE transmission.
Old Jan 23, 2008 | 02:45 PM
Krob's Avatar
Since its an 01 i am just gonna say its a 6speed with a bigger clutch. Till i find out different.
Old Jan 23, 2008 | 09:24 PM
gmctd's Avatar
Is yer hood rusted shut, where ya cain't look and see?
