nv4500 partial grind
Old Sep 10, 2007 | 02:38 PM
dutchboy's Avatar
Its a stock box, about 6 months ago when I would pull out in 2nd gear I could hear a rattling sound similar to the sound of a loose muffler(thin metal tapping together) this would only happen at low rpm's. Last week I took a road trip stopped to get fuel when I pulled out of the station, not immediatly after about 2 seconds I could hear the gears grinding in the trans., they would only grind for a second. This would happen in 2nd through 4th not in 5th. I ended the trip made the 100 mile trip home all freeway in 5th. As I was approaching my home shifting through gears, still grinding now in 5th as well. Is it the throwout bearing?
Old Sep 25, 2007 | 06:42 AM
wadecool's Avatar
Dutchboy, I had similar symptoms, and it was the rear countershaft bearing. The bearing had blown apart & the countershaft was loose. You can check it by taking off the rear tranny housing & look to see if you have play in the countershaft (below the 5th gear shaft).
Metal Twister
13
Dec 29, 2012 12:44 PM
gorms
Aug 28, 2012 11:12 AM
Seeder
Oct 30, 2007 12:31 PM
