Number 6 injector line
How do you get a wrench on it?
Crows foot?
I blead a guys injectors three years ago at a rest stop so I know it's do-able.
I just don't remember what position I had to get into to do it.
Never mind...piece of cake once you get the lifting lug out of the way.
Crows foot?
You don't have to bend anything. This is how I got it off when I replaced the VP: Seperate the wiring harnesses to make a little more room. Use a crows foot with a 1" extension on a 3/8's ratchet. You have to get the ratchet aligned right and you might only get a click or two turn before you have reposition everything. It doesn't take much before you can turn it with your hand. I heard you can get shorty wrenchs that will fit back there too.
Crows foot?
Crows foot?
I wound up buying this mid length 19mm snap-on wrench works perfect
i had a cut down 3/4's that i used, but it ya take the mounting barcket off ya can get a fulsize wrench in to it. it's actuly 19mm, but a 3/4 works fine. and most line wrenchs are wide and a pain in the A$$ to work with
Bushy
Jul 16, 2005 01:50 PM
