Nozzles or Injectors
Old May 5, 2009 | 04:22 PM
gellibee's Avatar
Just curious what the main difference between getting either new nozzles for stock injectors or the complete injector....would the end result be the same assuming my stock injectors are good?
Thanks
Old May 5, 2009 | 05:23 PM
Clunk's Avatar
Yup, most likely the result will be the same. The complete injectors will be shipped with the squirt (pop) pressure already calibrated. With nozzles, you'll need to have the local diesel pump repair shop do the calibration for you.
Old May 8, 2009 | 06:39 AM
smokinram99's Avatar
what calibration? even on mechanical injectors?
Old May 8, 2009 | 09:54 AM
Clunk's Avatar
Yup, the nozzles have a spring on the pintles that the injector pump pressure has to overcome before the pintles raise up off the seat and squirt. Each spring is shimmed so this pressure at squirt can be set to the Cummins spec. 4250psi +or- 250psi.
The pressure affects injector timing and spray conditions.
Old May 10, 2009 | 04:19 AM
thats ok Clunk thanks!
WestTexasRam
Oct 4, 2006 03:38 PM
WhiteRamDiesel
Mar 8, 2006 02:00 PM
singleturnout
13
Jan 18, 2006 06:14 PM
killfast1
40
Jul 7, 2005 04:15 PM
macaw
Feb 10, 2005 12:38 PM
