Not starting
Old Mar 4, 2016 | 11:51 AM
Charles 99's Avatar
Not starting
I have a 99 24 valve and when I go to start it I just get a click. There is no attempt to crank or anything. Both batteries are a couple months old and charged fine. I had the same issue a week ago and replaced the starter because of it. Now it's at it agin. I checked the voltage on the starter and it's fine. The only thing I can think of is that I'm parked at a weird angle and its causing some sort of problem.
And ideas or tips are greatly appreciated. Thank you
Old Mar 4, 2016 | 08:03 PM
jrs_dodge_diesel's Avatar
Welcome to DTR!
Usually a problem like this is caused by pitted and corroded contacts in the starter solenoid. That's a somewhat common problem on our Rams, and is easily fixed with a new set of contacts in the solenoid, plus a new solenoid plunger.
Do you still have the original starter? I hope you do, since that is a very well built and rugged starter. It's easily serviced and rebuildable. Unfortunately, a lot of aftermarket starters are not as well built.
Either way, let's start with an inspection. Pull the starter and put it on your workbench. The starter solenoid is the little block attached to the main body of the starter. Remove the three screws from the end cap and carefully pull the cap off. Remove the plunger, being careful not to lose the spring and ball bearing under it. Now look at the electrical contacts, should be nice and clean copper. If pitted/corroded/burnt, you'll need new ones.
Use this thread for reference, it was written by one of our memebers, BC847: https://www.dieseltruckresource.com/...tarter-141395/
Old Mar 5, 2016 | 08:08 PM
SIXSLUG's Avatar
I'd check your battery connections and cables, unless your new starter is a crummy rebuild, sounds like it isn't getting enough juice at the end of the cable.
Old Mar 6, 2016 | 09:31 AM
johnh's Avatar
jrs is dead on, i had the contact problem and replaced them with larry b's kit
here's what is needed
Larryb - LarryB's Dodge Cummins Denso Starter solenoid kit, 89-2006
Old Mar 6, 2016 | 11:53 AM
SIXSLUG's Avatar
He said he put a brand new starter in last week...
Old Mar 6, 2016 | 09:25 PM
Right, but he said he had good voltage to the starter, but no starting. That indicates to me of bad starter contacts, or a bad starter.
My starter did it to me twice, starter solenoid would close, but just made a clunk noise. No starting. Bad contacts in my case.
Old Mar 8, 2016 | 12:40 PM
SIXSLUG's Avatar
He may have good voltage at the cable end, but not the trigger wire from the ignition switch. Mine is so caked in oil I'm not sure I could get a reading off it.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
FORDNOMORE
Oct 31, 2003 04:02 PM
admin
16
Aug 17, 2003 10:07 AM
