no turbo boost
no turbo boost
2002 ..5.9 ...3500 dually....has clean and new fuel filter, clean K&N air filter, no OBD codes but I have no turbo boost...it starts fine runs fine, but no launch when you floor it , like it had before....275K miles but only modest problems like VP44 replacement but since Raptor install it has been bullet proof....any help is appreciated. Doc
Could be several different things. Do you have lots of black smoke when you give it throttle? That might indicate an intercooler boot has split or come off. If it's just gutless with no other obvious symptoms then I'd guess it's running in limp mode for some reason.
Limp mode is basically the computer defuelling trying to save the engine because it thinks something's wrong--like it can't sense any boost, for example. If that's the case then there will be codes that you can see by doing the key on, key off (three times) check.
Mike
Mike
Mike
Mike
The wastegate is a good thing to check. Also look for exhaust leaks between the head and manifold, and also between the manifold and the turbo.
It used to be not uncommon for 24v engines to lose exhaust manifold bolts, but I rarely read about it here in the forums anymore.
The lower driver's side boot off the intercooler can rub against the inner fender and end up cutting itself open where the metal seams together.
On mine I took a pair of metal pliers and bent the edge out away from the boot so the sharp side wouldn't touch it. The factory boots will puff when you floor it.
Something to check..
97dodgeram2500
Nov 1, 2009 11:51 PM
jcarrillo
Jul 10, 2009 08:24 PM
JSCumms2000
13
Sep 24, 2008 05:46 PM
vwjunkie53
19
Nov 9, 2007 02:27 PM
Bobcat698
18
Oct 22, 2005 12:27 PM
