No start issue
No start issue
Just a question if anyone else has had this happen.
went on a trip and parked the truck. came out in a hour or so and it cranked and cranked but would not fire. tried to wd-40 start no go. then disconnectred batts and reset obc and it fired on second try. Had good fuel pressure the whole time.
Thanks
PS we only have about 1000 on a new VP-44 and Fass.
have had 6 or 7 starts since.
Thanks
have you checked all your fittings? make sure your not getting air in the system and causing it too loose prime. if you call source auto / rip rook ill pm your his shops number there a diesel performance shop they just did my clutch on saturday if your not rolling let me know if i can give you a hand i am about 2hrs east of porltand
I do not seem to be sucking air at all. It my be a gremlin it has been starting and running fine even towing the fiver.
Least breaking down with a camper you can wait it out
you know what else you might check is connections on the pump or starter or any thing that might have came loose or is not properly grounded from corrosion from salt.
dan123dbl
Feb 13, 2015 05:47 PM
cgoaks77
Dec 9, 2010 09:06 AM
CoolumConst
Oct 11, 2008 10:00 PM
