No power steering, no power brakes
Old Mar 24, 2011 | 05:01 PM
c9buff's Avatar
I've got a 2000 Dodge Ram 3500 with the Cummins. Upon pulling out of the driveway, I lost power steering and power brakes. I thought it was the power steering pump and I replaced it with a new one. With the new power steering pump I still have no power steering or braking. I'm lost on this one, any suggestions as to what it might be is appreciated.
Thanks
buff
Old Mar 25, 2011 | 08:28 AM
jhenson's Avatar
Sounds like your hydro-boost went south on you. That's a dead giveaway if your steering and brakes go out as they are both run with the hydro-boost.
Old Apr 5, 2011 | 07:37 PM
drecu's Avatar
Check your Power Steering Fluid.
Old Apr 6, 2011 | 06:47 PM
buckied's Avatar
X2 on the hyrdoboost
Old Apr 7, 2011 | 08:32 AM
J BODY's Avatar
Wow! that was a spendy time consuming guess.
Old Oct 26, 2011 | 10:33 PM
loucool's Avatar
Hydro boost is ok, but steering fluid went dry..
Need advice on HOW to bleed fluid BETWEEN the power steering pump and hydro boost? Still have breaks and power steering. I let power steering fluid go dry several months ago, filled it, still has fluid - ABS and Brake lights are on continuously.
Help on this one?
Old Oct 31, 2011 | 03:32 PM
drecu's Avatar
It should be self bleeding. if those lights are on I would check the brake lines for rot/leaks going to the rear if you have air in the actual brake system or a leak you will get those lights. but the hydroboost will not set off those warning lights.
Hope that helps.
Old Oct 31, 2011 | 09:41 PM
loucool's Avatar
Thank you I did figered it out had a blown fuse It just so happen I hook up to my dads trailer at the same time and the lights had a short in them thank you
13
Dec 18, 2008 08:17 PM
wildcargo
Nov 29, 2005 04:20 AM
WHITEY
Sep 15, 2004 09:57 PM
RAK GUY
Apr 5, 2003 10:28 PM
Garz
Nov 17, 2002 02:02 PM
