No power stearing when cold
My truck has been doing this for awhile now but it keeps happening more often. It stears fine down the road but at low seeds in a tight spot like a parking lot or driveway its like the pump stops working and I have to use both hands to turn the wheel. It also only happens when the temp is below 25*. Is my pump or gear box going out? Or is the oil too thick? Any suggestions would help.
You've got water in your steering fluid.
Just siphon it out thru the filler with a turkey baster or equivalent. Run the truck for a little bit turning the wheels lock to lock and do it again.
I've gotten into the habit of doing this at every second oil change oil change and i haven't had any problems for years even at -30 or more temps.
I use Royal Purple synthetic fluid. I found it cheap and bought a couple of cases of it. A whole bunch cheaper than a pump in my mind.
Jeff
Jeff
Royal Purple
Jeff
Jeff
I just bought a couple quarts of Royal Purple synthetic PS fluid at the Base exchange for $9.00 a quart. I'm assuming you found it cheaper. Where!?
Thanks
