No fuel in the filter
Old Mar 29, 2008 | 08:50 PM
Matt Lambrech's Avatar
Angry No fuel in the filter
Just started my 01 truck and headed out the driveway. Truck died like fuel was shut off. It started up but died again and then no start after. I opened up the filter and there was about 1" of fuel in the bottom. The dealer put in an intank pump just last year and i maybe put on 5K miles since. Did I lose the pump or is it worse?
Last edited by Matt Lambrech; Mar 29, 2008 at 08:51 PM. Reason: Forgot which truck
Old Mar 29, 2008 | 10:30 PM
nickg's Avatar
Or your fuel tank is empty, because the fuel senders are known to read 1/2 tank and be empty.... throw a gallon or two in there just to be sure
Old Mar 30, 2008 | 05:21 AM
Fishin2Deep4U's Avatar
What's your fuel pressure???
Dave
Old Mar 30, 2008 | 10:59 AM
No fuel
I found the wire going to the aux relay that the dealer put in does not have power. There was some black rubber thing near the fuse box that when I took off a cap it was all corroded inside so no power to the relay. I jumped that thing and now hear the pump running. It seems to run a couple of seconds after turning off the key. Is this right? Now I will try to bleed out the VP.
Old Mar 30, 2008 | 03:00 PM
mini14's Avatar
it should run for 25 seconds if u turn key on then off.
Old Mar 30, 2008 | 05:42 PM
Talking Fixed
It was the wire for the aux relay put in by the dealer for the in tank pump.
There is a little fuseable link?? rubber piece that when opened was all corrosion like battery acid inside. I bypassed it and bled the injectors and back on the road. Thanks to all for your help and support!!!!
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
Lunyfringe
Jan 10, 2005 05:40 PM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
