New Walbro and new problem
Old Jul 11, 2007 | 11:41 PM
cstmfabman's Avatar
OK. I got the Walbro pump and big line kit and I wired it to the stock transfer pump wires with the harness extension that came with the big line kit. I bled the lines at the injection pump until there was no air and then let pressure build up again, but it wouldn't start. I decided to bleed some pressure off at the injection pump with the key off and when I tried to start it, it started. If I turn it off and then try to start it again, it will not. The only way to get it to start again is to bleed off pressure at the injection pump before I start it. I haven't driven it yet because my fuel isolater is leaking and I can't get it so stop, but it runs and revs fine when I finally do get it started. I don't have a fuel pressure gauge plumbed yet because someone stole it off of my garage bench, and I had to order a new one What is the deal, does the Walbro need a pressure regulator? In desperate need of some advise
Old Jul 12, 2007 | 01:55 AM
pind's Avatar
The walbro kit normally comes with a return line regulator, to bring the pressure down into the 15 - 18 range. if you do not have the pump regulated, you are setting yourself up for some serious problems.
Check out glacier diesel's website to see the regulator I am talking about. With it on there, no starting issues, and good solid fuel pressure.
good luck
Old Jul 12, 2007 | 09:21 AM
PaulDaisy's Avatar
If you do not have a return line from the Walbro using some sort of bypass regulator or relief valve, you are sending 100+ psi to the VP44 at idle and during cranking. If this is how you plumbed your fuel system, your IP's rotor may seize and it will be very expensive. Make sure you are not sending more than about 20 psi to the VP44 at idle. I don't think running a high performance LP without a pressure gauge is a good idea anyway, hopefully you get yours soon.
-P
bronco68
Feb 2, 2009 04:44 PM
Southern Pride
Jul 16, 2007 10:59 PM
UnrulyNFS
14
Oct 17, 2006 08:57 PM
cjones42
0
Jul 27, 2006 11:07 AM
B.Law
57
Jun 1, 2006 10:46 AM
