new vp44
Old Apr 5, 2007 | 10:26 AM
ram755's Avatar
new vp44
just ordered my new vp44 from MWFI, how long does it usually take to get? What puller work best (other than the 50.00 blue chip)?
Hopefully this will make me like my truck again, and maybe a little better fuel mileage to boot!
Old Apr 5, 2007 | 01:26 PM
Dinner's Avatar
When I changed mine my I used a regular snap-on puller...has 3 like points, put the bolts through it into the timing gear, and then thread the large centre "bolt" through it into the pump shaft, worked great. Obviously can't be too big or else you won't be able to get a wrench in between the rad, fan, etc.
Old Apr 5, 2007 | 05:05 PM
bill moore's Avatar
Mine took two two business days, excellent service !! I used the same puller as Dinner.
Old Apr 5, 2007 | 08:44 PM
bentwings's Avatar
Got mine overnight. I used a cheapo harbor freight puller and 2 of the intake bolts. These bolts can be a tight fit inthe gear but they are the right thread. I saw a picture of a guy using the lifting ring with a couple sockets. He drilled a hole between the 2 that are in it and used a bolt there.
Old Apr 6, 2007 | 11:28 AM
Farmer Brown's Avatar
I use a steering wheel puller. $25 will buy you a good one
Old Apr 6, 2007 | 12:41 PM
jriggs_18's Avatar
I made my own puller, btw- i didnt help my mileage when I did mine (also from MWFI), but so far its been a good VP
mopar440cu
Nov 28, 2012 10:33 PM
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
