New Valair clutch - clutch wont disengage
Hi, I know this has been posted before, but I cant find it. I just installed a new Valair heavy single disc clutch. They said my stock hydraulics would be fine, but I cant get it to disengage. I Can start it in gear with the clutch in, but it rolls forward. Once rolling, I can't shift. It's like the clutch isnt working. I think this is a common problem. What could it be? thanks, -Evan
Not having the clutch disk lined up right on the flywheel could cause the clutch to not disengage. Also, the pilot bearing being damaged when the transmission was slid back to the motor could be a possibility. If it didnt go back together real easy, thats what I would look into.
Verify that you're getting enough travel from the clutch slave. I'm not sure exactly how much you need. You could check in the service manual or maybe somebody will chime in here. Definitely call ValAir though--they're the experts and can probably give you some things to look at.
badmrb
Jan 3, 2007 07:18 PM
