New user, no boost!
Old Mar 28, 2005 | 04:09 PM
Wes in TN's Avatar
New user, no boost!
This is my first post here. I have an '00, 235HP, CTD with the 6-speed. I've only owned this truck for about a month so I'm still getting used to the Cummins. I pulled for the first time with it this weekend and was very dissapointed with it's performance, both in power and economy. I could hear the turbo spool up but I couldn't feel any increase in power. I am used to driving a Powerstroke and thought that maybe I just wasn't used to the power band of the Cummins at first but after the first grade it was obvious something was wrong because my old '96 PSD could run circles around this truck. I never got a check engine light and the truck shows no diagnostic codes. I checked for torn IC boots or loose clamps but didn't find anything obvious. I also inspected the impeller and it looks fine and spins freely. I had a buddy of mine hook the truck up to a scanner that displays real time sensor readings and the manifold pressure reading never got any higher than 4.6 inches of Hg which equates to about 2.3 psi. Where is the boost going? Could the wastegate be stuck open? If it is could a bad MAP sensor cause it and not throw a code? Any help is appreciated.
Old Mar 28, 2005 | 05:54 PM
mini14's Avatar
YES get a new MAP sensor while your at it checkout your IAT sensor
Old Mar 28, 2005 | 09:36 PM
Mopar1973man's Avatar
Check for leaking boots on the intercooler... common problem.
The boots have been known to rub the fenders and rub holes in them.
MAP sensor and IAT Sensors need to be cleaned (try cleaning first) or replaced.
You might take notice to your exhuast... smoke black, white, grey, blue??? Heavy or not???
That will give some more clues...
Old Mar 28, 2005 | 09:40 PM
Wes in TN's Avatar
I checked the intercooler boots, not obvious tears or loose clamps. No noticable smoke to speak of at any time. I did notice some moderate haze in the rearview mirror when pulling a grade with someone behind me at night though. Nothing is noticable during the day though. I'll try cleaning the MAP and IAT sensors tommorow after work to see if it helps anything. Thanks for the help so far.
Old Mar 28, 2005 | 09:58 PM
tool's Avatar
Definitely sounds like MAP sensor if you are only seeing 2.3 pounds.........
Mine throws an overboost and says 75 IN HG, how many pounds is that???
Old Mar 28, 2005 | 10:00 PM
You might have to check the boots with soap water. To find small holes... Somewhere on the site someone built a device to pressurize the system for checking the boots and intercooler for leaks.
But yea start simple and get to the harder stuff...
Old Mar 28, 2005 | 10:46 PM
SjLingenfelter's Avatar
Shoulda stuck with a ford....
BTW Im a ford guy stuck on a Dodge site cause...You can beat the people here. And Welcome to the site.
Old Mar 29, 2005 | 06:55 AM
Wes in TN's Avatar
~37 psi
Old Mar 29, 2005 | 06:57 AM
Wes in TN's Avatar
After my first haul I'm starting to wonder. My old Ford pulled like a scaulded dog, so far this Dodge is pretty anemic. Hopefully fixing my problem will wake up this Cummins.
Old Mar 29, 2005 | 07:55 AM
Wes in TN's Avatar
Assuming cleaning it does nothing does anyone have Cummins and/or Dodge part numbers for the MAP sensor?
Old Mar 29, 2005 | 09:29 AM
tool's Avatar
woah.................... How could a stock truck be getting 37 PSI??? The sensor must be shot.
Old Mar 29, 2005 | 07:19 PM
jrs_dodge_diesel's Avatar
Click here for a full list of common part numbers for our trucks.
Up at the top of the web page underneath the DTR main banner is a link for TECH FACTS. Lots of great info on our trucks in there.
Old Mar 29, 2005 | 09:45 PM
tool's Avatar
I just replaced the MAP sensor tonight, it was like a 5 minute job max. greased the connections with dieclectic before reinstall.
Seems if maybe the truck runs smoother??? I ran 'er hard after the install, I need to check and see if it threw another overboost...... Hope that has fixed it.
Teh old sensor was a little gummed up with carbon and crap, not sure how that gets on it. I'll pull the IAT tommorow and either clean or replace that too. Hopefully it helps.
I got the MAP from Cummins was $86, Dodge wanted $145.
The IAT from Dodge is $45, Cummins wants $80 something......... that's a first for me! Cummins more expensive than Dodge??
Old Mar 29, 2005 | 09:53 PM
high country's Avatar
cummins is WAY cheaper then dodge, the P#338747 is for the round MAP sensor and P#3417030 is the flat one. you might want to check at reliablegoods.com as they have cummins parts for a great price.
Old Mar 30, 2005 | 01:05 PM
tool's Avatar
I replaced the MAP and it is still throwing the code saying I am boosting like 36 psi on my stock truck! What gives???
How is this possible?
