new inj pump and new lift pump p 0216
Old Aug 19, 2008 | 03:23 PM
camerd18's Avatar
i just replaced the injection pump and lift pump i cleared codes and drove
it again it still has a lil dead pedal and kicked the 0216 code again
fuel pressure is good any ideas on what elese could cause this prob?
Old Aug 19, 2008 | 04:27 PM
dozer12216's Avatar
It scares me that got code again after clearing. However on one replacement that I did, after three hours of driving it almost died. Cold only figure some trapped air finally worked it's way through pump. Not done now in 20,000 Miles.
Old Aug 19, 2008 | 10:54 PM
rebal's Avatar
check to see you have good clean connections at pump PCM , ECM .apps a dirty contact could cause it. where did the new pump come from?
Old Aug 21, 2008 | 09:46 AM
camerd18's Avatar
its was a reman from a certified bosch inj shop
was told it could be a line problem?
Old Aug 21, 2008 | 04:14 PM
PaulDaisy's Avatar
That is scary. I would call the place I got the pump from right away. My bet would be, a lemon pump. When I replaced mine and reset the codes, they did not come back.
Mind you, I had to reset the codes using a code reader. Disconnecting battery cables does not clear the 0216.
Old Aug 21, 2008 | 07:20 PM
RickCJ's Avatar
Good pumps start at $1500 and up.
China cheapies start under $1000.
DodgeCowboy
Jun 25, 2009 06:21 PM
9 sec camaro
20
Aug 26, 2006 01:30 PM
G-NOTE
Mar 9, 2006 01:13 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
