new here need help
Old Aug 6, 2012 | 07:59 PM
tfg130's Avatar
new here need help
I have an 02 2500 it will start and idle just fine, but when I drive it sputters and blows white smoke. I tried the APPS reset it seemed to work at first but the same thing. I checked the turbo there seems to be no play the oiler tube is clear. It is giving me a DTC of 0230. I replaced the lift pump a year ago. Any help would be appreaciated. Thanks.
Old Aug 6, 2012 | 10:10 PM
BigIron70's Avatar
Cummins Guru
Sounds like another bad lift pump. Check pressure and flow to the injection pump. Check fuel filter for restriction and contamination. Stock lift pump?
Old Aug 6, 2012 | 11:36 PM
tfg130's Avatar
It is an OEM lift pump would you recomend something different
Old Aug 7, 2012 | 06:20 PM
whiskers's Avatar
The OEM pump is not the best. Get a FASS or Raptor or Airdog. Your IP will thank you!
Old Oct 23, 2012 | 07:02 PM
DodgeCowboy's Avatar
DTR's Cow Boss
I have a two year old fass ddrp thats putting out 20psi idling and about 10-12psi hard under load and not missing a beat. I have the po 0230 code as well any solutions?
Bushman512003
May 2, 2012 05:32 AM
Iguess
18
Apr 26, 2008 01:29 PM
Dieseldude4x4
Dec 23, 2002 08:56 PM
Dieseldude4x4
Oct 17, 2002 04:58 PM
