NEED TOW HOOKS, CANT FIND!!
IS THERE ANY WAY TO GET TOW HOOKS ON THE FRONT OF MY TRUCK? I HAVE HEARD THAT THERE WAS AN OPTION FOR THEM FROM THE *******, BUT CANT SEEM TO FIND THEM. IS THERE ANYONE WHO MAKES THEM FOR DODGE 2500'S?
Re:NEED TOW HOOKS, CANT FIND!!
[quote author=j link=board=4;threadid=6120;start=0#55676 date=1035235535]
DOES IT MOUNT IN A FACTORY LOCATION, OR DO I NEED TO DRILL HOLES FOR THEM?..........
[/quote]
Here is a good write up with photo's of the install.
Tow Hook Installation
phox
[/quote]
phox
phox............ sorry bout the caps, but our computers in our cars at work have it fixed in and always on so it's just easier for me to read what i wrote. thanks for the info on the hooks. for some reason my local ******* cant find them in his book of parts. i should know better than to listen to them anyway, which is why i drove an hour away when i bought my truck...... thanks again for the info.
I put two chrome ones on mine with the spring clips. I think one hole was there and I had to drill the second. Use good grade eight bolts, don't get the cheap stuff. Put a heavy washer on the upper side of the frame to give you more bearing surface too. I'll add a pic if I can find one. Picked them up at a local tractor supply store if I remember right. You can also check www.awdirect.com. I buy a bit of stuff from them, they are not cheap but have quality stuff.<br>If the pic works, the hooks will be right in front of the oil filter gaurd. Let me know if you have any questions. Good luck.
thanks all for the help, now i have a bit more info to go with. i think i'll try the ******* first since i need to take the truck back for warranty work anyhow................ thanks again
Bowser50
15
May 28, 2010 09:37 AM
1985cucv
Dec 30, 2009 07:43 PM
Have you checked J.C. Whitney or Cabelas?. just a thought.
