need specs on engine rebuild
Old Sep 28, 2009 | 08:05 PM
77machomopar's Avatar
anyone one have the specs on clearance for an engine rebuild. i dont have a FSM. So any help will be greatly appreciated
Piston Ring Gap
connecting rod bearing clearances
crank bearing clearances
Old Sep 28, 2009 | 08:19 PM
OldDodgeOwner's Avatar
These are out of the 2000 FSM
Piston Ring Gap -
End Gap (Top) 0.400-0.700 mm
End Gap (Intermediate) 0.250-0.550 mm
End Gap (Oil Control) 0.250-0.550 mm
Connecting rod:
Pin Bore Diameter(Max.) 40.042mm
Side Clearance 0.100-0.330 mm
Crank bearing:
Main Bearing Journal Diameter (Std.) Min. 82.962mm
Main Journal Out of Round (Max.) 0.050 mm
Main Journal Taper (Max.) 0.013 mm
Main Journal Oil Clearance (Max.) 0.119 mm
Rod Bearing Journal Diameter (Std.) Min 68.9745mm
Rod Journal Out of Round (Max.) 0.050mm
Rod Journal Taper (Max.) 0.013mm
Rod Journal Oil Clearance (Max.) 0.089mm
End Play 0.100-0.430mm
Gear Backlash 0.076-0.330mm
Old Sep 28, 2009 | 08:36 PM
thanks you people are awesome. are there any specs in the book that i need to know
Old Sep 28, 2009 | 08:45 PM
There's 4 pages of specs. I'm copyin em by hand though, so I can get specific ones for ya. I've never done anything internal with these motors so I couldn't tell ya what all you'll need.
Old Sep 28, 2009 | 08:57 PM
i cant think of any more that i need right now. but thanks for the info.
Old Sep 28, 2009 | 11:23 PM
No problem. Let me know if there's any other ones you need.
1992gen1_fan
Jan 23, 2011 01:09 PM
GSP7
Nov 1, 2010 04:32 PM
06RAMCTD
0
Dec 19, 2006 04:15 PM
The Burning Rom
Jun 23, 2005 09:55 PM
