need help or going to sell
Old Jun 5, 2007 | 11:01 PM
Big Dblue's Avatar
With my edge ez and my afe i have went from stock at 16 or 17 up to about 20 ro 21. And BTW i always have my foot in it.... LOL... What can i say... I LOVE the smoke. lol
Trapper.
Old Jun 5, 2007 | 11:37 PM
kenny1987's Avatar
lol well thats kool but i just dont get it i dont the millage everyone else does!!!!!!!!!!!!!!!!!!! any help
Old Jun 5, 2007 | 11:57 PM
stuckey200224's Avatar
Originally Posted by WRTN
Have you tried cleaning or replacing the IAT sensor?
http://www.dodgeram.org/tech/dsl/sensors/IAT/clean.htm
what he said
Old Jun 6, 2007 | 12:56 AM
kenny1987's Avatar
do i just take the sensor out and use some cleaner or degreaser? something like that what does that thing do anyways
Old Jun 6, 2007 | 01:22 AM
EverydayDiesel's Avatar
it senses the air input temperature or the temperature of the inlet air.
in a speed density setup it is used in conjunction with the manifold pressure to calculate how much fuel is needed. (im not sure if the CDTs are SD tuned but this is how it is in race cars that I drive. I havent found a mass air flow sensor so Im betting that they are speed density) I am still very new to diesels
Old Jun 6, 2007 | 01:40 AM
kenny1987's Avatar
thanks but u lost me ..........i am from texas man talk simple will it help? lol realy i appreciate the help but i just wana get better mpg will a stage 2 and 4" help that much i heard of a thing called the fuel cell something about energizes the fuel to burn better and give better millage any one know anything? i am desprate
Old Jun 6, 2007 | 02:37 AM
its just a sensor thats used for calculating how much fuel your engine needs.
I think at $30 and its ease of install ... its worth a shot.
Im going to replace mine soon to try and get some of my mileage back
Old Jun 6, 2007 | 03:15 AM
kenny1987's Avatar
ok thanks i also heard that your intercooler lines could have some cuts from the fender and you would loose millage ? dont know but i am going to check that also what should my truck get? i think around 18 or 20 just wandering?
Old Jun 6, 2007 | 10:15 AM
Big Dblue's Avatar
My friend had this happen to him and he had to replace the hose. It made a little noise and lost mpg! He just bended the metal back just a little to put your fingure all around and that did the trick. When i bought my truck, he showed me and i did it before anything happend. Hope this helps. How much increase did you get on your afe stg 2? I at least got 2 to 3 mpg better.
Trapper.
Old Jun 6, 2007 | 10:28 AM
chuxtruk's Avatar
I think I'd have it placed on the computer for a diagnostic reading and then see what that comes up with and go from there. I'm sure that's what the local dealer does here and then they hope that you'll let them fix it. Depending on what it is, they'd be half right....
Did you check for codes??
Old Jun 6, 2007 | 12:07 PM
patdaly's Avatar
Dont forget to make sure your fuel filter and prefilter are in good shape.
Do you have a fuel pressure gauge on it?
I saw about a 4 mpg drop in the last tank before I changed them, so far it appears as if I am back to my old mileage.
Old Jun 6, 2007 | 12:50 PM
what is a prefilter? where is it located?
i changed the fuel filter with this document
http://dodgeram.org/tech/dsl/filter/00fuel_filter.htm
Old Jun 6, 2007 | 01:03 PM
AggieJustin's Avatar
Do you have any gauges? I'd check your fuel pressure to make sure that your lift pump hasn't gone bad. If you have a boost gauge, what kind of boost pressures are you seeing? This will give you an indication of a boost leak.
Old Jun 6, 2007 | 04:40 PM
patdaly's Avatar
Whoops, according to the 24V manual, you guys don't have a prefilter.
On the 12V units it is right below the fuel heater.
Sorry for that.
Old Jun 6, 2007 | 06:22 PM
kenny1987's Avatar
how do i check codes and i dont ahve any gauges nor a pressure gauge i need to get them but i dont know how to hook up pyro!!!! nor boost gauge diff sub codes ???????????????????
