need help!!!!!!!!!!!!
Old Nov 5, 2006 | 06:28 PM
hottapper1's Avatar
Exclamation need help!!!!!!!!!!!!
Ihave a 98.5 24 valve heres the deal the truck has good fuel pressure. we put a new vp44 ,injectors,new cam sensors and the truck still wont start .we rig up a fuel line and injector off a 95 and the pump wont pop off the injector.is there something that does not allow the pump put out the right amount of pressure as far as sensors or codes.we put a mac scanner on the truck but the scanner could not communicate.
Old Nov 5, 2006 | 08:19 PM
mrclean's Avatar
You stated that the pump wouldn't pop the injectors. Are you getting any fuel at all to the injectors?
Old Nov 5, 2006 | 08:42 PM
hottapper1's Avatar
yes it is getting fuel two the injector but just not enough two pop it off could it be we just got bad vp44.
Old Nov 5, 2006 | 08:44 PM
slim51015's Avatar
Are you trying to use 12 valve injectors in a 24 valve?
Old Nov 5, 2006 | 09:13 PM
hottapper1's Avatar
no no no we are trying to see if it has enough pressure to pop off a injector but it wont.is there something else that would keep it from putting out enough pressure two pop off a injector.
Old Nov 5, 2006 | 10:05 PM
blackdiesel's Avatar
Registered
do you know if the pop off presure is the same for a 12v and 24v? is the motor turning over fast enough? low batterys? just a thought.
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
coupdetat
Jan 17, 2007 09:23 AM
