my first oil change....
im doing the first oil change since i bought my truck i was going to use rotelle 15w40 and a wiks filter...but i need to know how much oil...not really sure on the amount of quarts it holds.
the Rotella 15w40 is what most of us on here use. You should only need 11 quarts of oil for her. i found Sams club has 3 one gallon cases for only $26. The Wix filter should be fine, i get my Fleetguard Stratapore filters from Geno's
Straight from the service manual....
A few things....fill the filter before you install it. When you fill it, wait a sec and you will see the level in it drop, then add some more.....repeat until is is full, but not so full you spill it when you install it. Then add the remainder of the 11 qt total to the motor, let it settle and check the level. You may need to add a bit mor, maybe not.
jmccart
13
May 27, 2009 09:45 PM
1stTimeAround
Oct 10, 2004 04:02 PM
doitl8r
Jun 4, 2004 11:14 AM
snice
14
Apr 29, 2003 08:41 PM
pwabbott
Nov 15, 2002 03:28 PM
